Have fun looking at Furds. Thanks for keeping it simple Honda. Always great to talk about something that is no longer available. 🤷♂️
Have fun looking at Furds. Thanks for keeping it simple Honda. Always great to talk about something that is no longer available. 🤷♂️And the base 3.5L (non-turbo) F150 is rated to tow a whopping 5100lbs.
According to most internet truck owners, 5000lbs towing does not a truck make, so Ford gave it an extra hondo for good measure. 😁
Well, if it makes you feel any better, the 3.3 only tows 5000 in 2wd, but the 4wd ups it to 5100.Have fun looking at Furds. Thanks for keeping it simple Honda. Always great to talk about something that is no longer available. 🤷♂️
Oh my, chippy, chippy. I never made a statement about the 3.3L. I’ll re-phrase the statement I did make, regarding the F150 3.5L........when properly equipped, a 4X2 is rated to tow 14K lbs.Well, if it makes you feel any better, the 3.3 only tows 5000 in 2wd, but the 4wd ups it to 5100.
Do you have info saying the FWD Rigi could not pass that test? Would be an interesting read.One of the SAE 2807 towing capacity tests is a start from stop pull up a 12% grade for 5 meters. The vehicle has to accomplish this task 5x within 5 mins. I’m thinking this may be the limiter for the FWD RLs. Not sure the drive wheel would get enough traction with 500# of hitch weight in this scenario. A 2WD with RWD, such as the F150, would not be prone to the same drive wheel traction issues.
The Nissan Pathfinder is rated to tow 6,000 lbs. with 600 lbs. on the hitch even with FWD and it has a CVT.One of the SAE 2807 towing capacity tests is a start from stop pull up a 12% grade for 5 meters. The vehicle has to accomplish this task 5x within 5 mins. I’m thinking this may be the limiter for the FWD RLs. Not sure the drive wheel would get enough traction with 500# of hitch weight in this scenario. A 2WD with RWD, such as the F150, would not be prone to the same drive wheel traction issues.
I'm sorry, I thought we had gotten past that already. My apologies.Oh my, chippy, chippy. I never made a statement about the 3.3L. I’ll re-phrase the statement I did make, regarding the F150 3.5L........when properly equipped, a 4X2 is rated to tow 14K lbs.
Ahh, No ! Don’t really Care !! I got into enough Statistical s**t when I was a Flight Engineer for the Air Force. So now, if it Breaks ... just Replace ITNice I/O rig. That photo angle really makes the Rigi look small. Don't suppose you monitor TFT, out of curiosity? Ambient temps when towing? Steep/long ramps?
My comment was addressing the RL‘s FWD tow rating of 3500 lbs vs 5000 lbs for AWD. From what I can tell, the Pathfinder’s tow rating isn’t J2807 compliant so its hard to compare it to RL’s rating. But I will say Nissan’s marketing is pretty slick. 😀The Nissan Pathfinder is rated to tow 6,000 lbs. with 600 lbs. on the hitch even with FWD and it has a CVT.![]()
