For the last several thousand miles, I've noticed a pair of sounds from under the hood, one intermittent during idle, the other when AC compressor is engaged.
First: *sometimes* during idle, especially after reaching full operating temp, I hear "marbles" from under the hood. Definitely around the serpentine belt, definitely below the PS pump. This noise has been present for quite some time, and seems to be increasing in volume and frequency of occurrence, but always sounding like marbles bouncing around, usually noticed when sitting in traffic, window down, sound bouncing off the car next to drive side window. It's been a bugger to hear with hood up cuz it comes and goes.
Second, when AC is engaged, I hear a sound best described as d-d-d-ddeeee-d-d-ddeeee-d-d-dddeeeee. This is never heard inside the cabin, but is clear when standing outside the vehicle and appears to be originating down low in the AC compressor area. With hood open, the electric fans mask the sound enough to make locating its source difficult.
At first, I thought both sounds were attributable to the AC clutch, marbles cuz the clutch is disengaged, d-d-d when engaged - both indicating a spinning mass issue and pending failure, I thought. Today, I had time to stop by for a quick visit with helpful Harry over at Premiere Auto Service here in San Marcos. He was kind enough to loan his stethoscope and probe a few key spots in the rotating accessory assembly. He nailed the idler and tensioner pulleys and let me hear it for myself.
So.... armed with new info, I looked up relevant info in the FSM and started checking out parts cuz this is the kind of repair I'm comfortable with.
Pulleys are cheap @ around $30 for the pair, while a new tensioner assembly is $145. Cheap Bastard that I am, cheap is attractive but I don't wanna replace pulleys only to have the tensioner crap out in a few thousand miles.
Honda Parts Cheaper:
FSM says if tension position indicator changes between motor off and motor idle, replace the tensioner. It definitely changes position, but only by the amount shown inside the red circle below, which is about the width of the indicator mark cast into the assembly:
06 has 127K on the clock and I wanna keep her for as long as she'll have me. What do you guys say about this? Drop the cheap bastard routine and go new? While I hate spending money needlessly, I have no gauge to measure life expectancy of the tensioner itself.
Your wisdom is welcome! And thanks in advance.
