[UPDATED 10/19/16 to save you scrolling - added pics of 17x8 35mm offset Ultra Spline CUV black with machined finish and Kumho AT51s in 245/65/17 size to this post below, on Modern Steel Metallic RTL-E. This combo weighed identical to stock on our scale and has roughly same outside diameter & gear ratio. If you're looking for better traction AT tire with "triple peak" logo certifying deep snow performance (so you don't need to chain up as often, depending on regional req'ts of course), the AT51 has proven to be very nice in ride, handling and quietness.]
As stock G2 wheels are 18x8 with 55mm offset, has anyone weighed these yet? [EDIT: 27.5 lb/wheel + 31 lb/tire = 58.5 lb complete stock assembly]
How do G2s compare against R1 wheel specs?
Looks like there are some 20-21 lb options at Tire Rack's fitment of the '16 Pilot that might look OK with the RTL-E (MSM color) we ordered.
Has anyone installed or even mocked-up photos of alternate wheels on the G2? I'd like to see the G1 wheels (like at the top of this forum's pages) modeled on an G2 since they might be similar offset/fitment & reasonably affordable used.
I've seen one pic of the silver G2 with aftermarket wheels & it looked plenty tough.
Not the biggest fan of the wheel styling once you move up from Base config of the G2 (and realize it's subjective). Thanks for sharing any options or links (was not able to find it in search yet).
