1 - 9 of 9 Posts
Does anyone know the stock radio harness colors for the following wires ground, positive, remote, and dimmer? I'm looking to install my omnifi mp3 player and I want to splice into these wires. I know that black is ground and red is power blue is remote and orange is illumination from previous stereo installs. However, I'm not too familiar with Honda and their radio wiring. Basically what are the factory harness colors that I need to splice into to make this work. I will post some pictures when I've completed this project.
12 Volts - white
Ground - Black
Ignition - yellow/red trace
Illumination - red/black trace
Sorry, the factory radio does not have an amp turn - on signal. It might, but chances are it is very low voltage. (??mv)
absame said:
Is there a wire for muting the radio for connection to a phone hands free kit?
Usually not for factory radios. But you could create one with a pair of wiring harnesses (one male, one female), a 4PDT relay, and 4 high power resistors. (As mentioned above, if you do this, please use a pair of harnesses so you don't have to actually cut the factory wiring!)
1 - 9 of 9 Posts
