1 - 6 of 6 Posts
title explains it all. anyone know of any existing non retrofit headlights that i would put on my soon to be ridgeline?
all are DIY? . im looking for a drop in replacement that i dont have to cut **** up to get them to work. thanks
There are kits that require less DIY work such as the D2S from The Retrofit Source, but even that kit requires you to bake the housings, pry the covers off, cut the back part of the bulb mount, trim the shroud, and wire them up. It's about as easy as it can get short of having someone else do the retrofit for you.
1 - 6 of 6 Posts
