That would make sense given the 60/40 split bench seat.
That would make sense given the 60/40 split bench seat.Good questions but wouldn't that middle seating position just be considered the same as the other outboard seat. When you flip that side up it's all one seat. I wondered about this also nice features they get.
Thanks for checking.Made me go out in the cold and check. The perforated sections of the rear seats only heat. The centre section is solid leather and does not heat. So, only the outboard rear seats heat and that heat is isolated to the perforated leather sections of each seat.
Okay, thanks!I have the Sport and it doesn't have rear seat climate controls, the rear climate can only be controlled by the front panel.
That's a good question! Haven't spent a lot of time in the back seat, but so far they just seem to be space fillers. I'm not sure what you could use them for.So are those little cubbies under the vents usable for anything or just space fillers?
No! Those are not just space fillers! I changed my rear dome/reading light bulbs to LED and the top cubby was the PERFECT place to put the factory bulbs instead of throwing them away! 2k miles later they're still happily rattling around in there. LolSo are those little cubbies under the vents usable for anything or just space fillers?
All I can get on my 2022 rtle is low ac from the rear setting on. No idea how to get it higherHow do you set the rear temp & fan settings differently than the front? I know the rear will match the front using the sync function. I can see the rear settings on the front control panel but that's it. The owner's manual talks about a rear climate control panel but my BE doesn't have one. What am I missing?
