1 - 11 of 11 Posts
For anyone interested, I have just completed the install of component speakers (separate tweeter and woofer) in the rear doors. Yes, I successfully drilled the door panel and everything fit. Nervous?... You bet! Pictures will follow.
Nicely done!
These are for the people on rear seat, aren’t they? Or, do you feel these improve the sound quality to the ones on front seat somehow?
Discussion Starter · #4 ·
Yes, I installed them to improve the sound quality in rear, match the front set I had already installed, and it turns out that it improved the overall sound for the front too.
Discussion Starter · #6 ·
If you're asking what I used to replace the stock speakers, I used JBL GX600C. They're a 2-Way component package with a crossover.
No, I am asking what type of speaker did you replace (OEM). Are they midrange speakers or 2-ways? Crutchfield has them listed as 2-way, but some times crutchfield is wrong so I just wanted to check.
Also, what ohm are stock, 2 or 4? It might say on the back of the stock speaker.
Thank you
perfect, thank you very much! I didn't think they'd be 2-ways. I hate that crutchfield suggests replacing a mid with a 2way :(
Nice job on your install btw, looks clean
I'm curious what the DSP unit is sending to the rears - full spectrum or is there a high frequency cutoff like for the front door midranges. Are you getting decent output from the rear tweeters?
Discussion Starter · #11 ·
I'm sorry I haven't responded to your question. I didn't see the notification email.
Yes, I am getting decent output from the component rear tweeters. I've ridden back there and another family member too. We both noticed a difference.
1 - 11 of 11 Posts
