What did I do today:
Replaced the Door lock actuator on the right rear door. Part Number 72115-SDA-A01
Steps: Tools: 10mm deep socket, Large Phillips, small Phillips, very small flat head. Trim Removal tools, Blue thread locker.
0. Start with window in the UP position.
1. Remove door Handle screws. The is is done by removing the trim cover to expose two screws behind the handle.
1A) (OPTIONAL) Then undo the cable. Take care not to break the plastic retainer that holds the cable to the handle. You dont have to do this step. You can wiggle the entire handle sideways thru the panel when you are removing it in step #5
2. Remove the screw inside the door holder.
3. Pop the door trim using "door trim removal tools" to prevent breaking the plastic clips.
4. Remove plastic trim above the door lock.
5. Lift door trim up and off the window lip.
6. Unclip the Power Window connector and the bulb from the low corner of the door.
7. Remove white plastic sheet carefully from right side. There is a plastic hole cover in the upper right, pop that out first so that you dont tear the sheet.
8. Remove window track bolt. 10mm socket.
9. Remove screw that holds the Door Pop Up latch.
