1461 - 1467 of 1467 Posts
To fill the trunk with a case of beer while listening to tunes emanating from the bed.
I hate it when the door goes all the way and ding, I hardly ever have the door wide open to get in, or maybe Honda installed them in error,
I just asked if someone tried the swap, that is all.
Purchased my checkers over the winter. Installed them yesterday. It really is as easy as everyone says. I did the driver side then talked my son through him doing the passenger.
I did his a couple of months ago and it makes a big difference putting items in the back seat. I have also replaced the rear tailgate latch with a locking color matched lock, both of these things are simple to change out even if you don't have any mechanical skills.
Update 1-22-20: New details have emerged on 2020 rear hinges. It looks like the prefered method for 2017-2019 models who want larger rear opening should use the front door checks from 2017-2019 on rear. The 2020 rear door checks require 2020 rear hinges to function properly on 2017-2019 models. See post #1294 for video explination. Thanks gravis86!
Original Post:
I increased the rear door opening by installing a set of front door stops/ checks on the rear and it works perfectly. No rubbing or conflicts of any sort.
P/N Left: 72380-TG7-A02 (replaces 72380-TG7-A01)
P/N Right: 72340-TG7-A02 (replaces 72340-TG7-A01)
How to install in post #412 (Thanks ValJean9430)
Just did this yesterday as one of my 4th of July Ridgeline projects. Makes such a huge difference, especially when having to place a child car seat or reaching in to put my grandson in or take him out of the seat.
Just be careful removing the speaker. Once the top screw is removed, just slightly twist the speaker a little sideways to allow the lower square clips to release from their mounting holes. I didn’t know how to get the first one out and broke the lower clips. Once I saw how it was mounted I was able to remove the 2nd one without a problem.
