Getting some body vibration at 55+ MPH. rear drive shaft u joints seem tight (I was unable to see movement when trying to twist the yokes) and are rust free. I then checked the rear half axles. I would expect in and out movement for suspension travel but I get vertical movement and visible movement where the shaft meets the diff. when I move the shaft
vertically. The portion in the image rocks up and down. The front axles don't do this. Is this normal or are the CV joins worn? Thanks!
