Hi All,
Not a super critical issue, but somewhere along the way I've lost one of the upper phillips screws that hold the rear splash guards on. I have a replacement screw on hand, however it seems like that there should be a U-nut or some other backing in behind the wheel well plastic that would allow the screw to bite into and cinch down.
Right now, the screw slides into a void and all of the random U-nuts I have kicking around are too small or shallow to try and jam in there. I've tried to look/poke/feel around in behind, but it's full of ice and freezing outside. The local Honda guy had the screw, but none of his (or Bernardi Parts) catalogues list any part associated to that part of the bumper.
If any of you have had this area apart before, are you able to recall what, if anything, normally provides the backing for that screw? Would it be a U-nit clipped onto the wheel well plastic? It's too miserable out to try and pull the other side and have a look
Cheers,
Tom
Cheers,
Tom
