1 - 13 of 13 Posts
I saw another post in which the poster said he/she ordered rear splash guards and installed guards themselves. I can operate a cordless drill fairly well but that's about my limit when it comes to DIY auto-customization. Is this install relatively easy?
SS,
I went to that site but my browsers (Firefox & IE) wouldn't open the PDF. Is saw a post that mentioned using a right-angle attachment for the drill. I don't believe I've ever seen one of those before.
jam
You don't need any tools other than a phillips head screwdriver (stubby one) unless you take the wheels off... and a flat head screwdriver to pop the plastic rivets.
jam2004 said:
SS,
jam
Green With Envy Moderator
jam2004,
I had never done any type of autocustomization either until today when I installed a new brush guard. Just read the instructions and go for it. Take your time and everything should go just fine.
Discussion Starter · #7 ·
Zero,
I just ordered it from H & A. Also bought some touch up paint. While I was spending, I couldn't resist buying the remote control Ridge for my daughter and a black cap for yours truly. Thanks for the encouragement.
jam
No problem.
That remote control Ridgeline is a really neat toy. And touch up paint is always a good idea. I bought some from H & A as well.
The rear mud flap are a five minute install. It'll probably take you longer to find a stubby screwdriver in your toolbox than it will to install the flaps.
They really do help keep splash off the rear quarter panels.
Installed the mud flaps and the roof rack this weekend. They were both pretty easy. Mud flaps - 10 minutes (5 to find the screwdriver) and the roof rack took about 1 1/2 hours but I cheated and used a air cutoff tool to trim the molding rather than the recommended hack saw.
Jam, the rear splash guards are very easy to install. It took me 15-20 minutes. Each side is two phillips head screws and one push-in clip each.
I am one of the least mechanically inclined people in ROC and this accessory don't get any easier. I even ventured and put the wind/bug deflector on too!
Good luck with your (15 minute) install!
Discussion Starter · #12 ·
Hopefully they arrive this week from H & A. Thanks again everybody. I'm getting a bunch of stuff done to my Ridge tomorrow at a local truck custom shop. I'll take some photos after they finish and after I install the mud flaps.
jam
I installed these a few weeks ago, and it is indeed easy. I had two minor hitches:
  • the instructions don't say to remove the old plastic rivet, nor how to do so. If I recall it just pops off with a screwdriver.
  • 1 pair of screws that are reused to attach the flaps weren't long enough. I had to substitute my own screws.
1 - 13 of 13 Posts
