1 - 17 of 17 Posts
Anybody got any tips for removing the "HONDA", "RIDGELINE", and "AWD" badges from the tailgate? I always remove this stuff and the dealer name, but my last few vehicles just had decals. The raised letters are a pain in the butt to wash and wax around.
Thanks. I'll try it with some 20 lb. monofiliment fishing line.
Wow. Leave it to Honda to give advice on how to do this!
This may not be relevant to the Ridge, but I will add that I've removed badges from Honda motorcycles in the past ("we don't need no stinking badges!") in fact off a brand-spanking-new Valkyrie gas tank, and was amazed at the abuse the new paint job tolerated. Had to use a hair dryer and Goo Gone and god-knows-what-else but the paint job was as beautiful after as before. Scared the hell out of me to do it, but I didn't need a decal stating that gasoline is flammable! Good grief!
Of course, YMMV!! :eek:
I used a hair drier and dental floss it worked great and only took about 20mins.
I think it looks much better now
Discussion Starter · #7 ·
A little bit of heat from a heat gun and some 20 lb test fishing line cut like butter and the finish was georgeous after a little wax. I took the HONDA, RidgeLine, and 4WD badges and glued them to the back of my 94 Chevy Cavalier wagon I use for a commuter car. Looked great against the rust and dents. Hope nobody from Honda sees it and sues me for "defamation of car character". Got quite a few laughs from co-workers. Maybe I'll post a picure later.
Take a pic of both. Wonder if it might frustrate a meter maid when writing a parking ticket and has no clue what make or model the truck is and walk on although just the plate number is probably good enough.
I could have used this a week from last thursday when I was parked on the side of the road during road cleaning hours. I should cover up my vin too.
Counterfeit Ridgeline like the mini cooper commercial :D
Discussion Starter · #11 ·
Picture is posted in new thread titled "2nd RL used $600"
Fishing line and a blow dryer did mine with no trouble. In fact you can use your finger to get the gummy adhesive off and clean with goo gone then wax.
Just de-badged my truck about a week ago. All i did was put a paint scraper under part of the badge and popped off all the badges mainly letter by letter. Be carful tho to not scratch your paint obviously. After this there was a lot of adhesive left on the paint. I used goo gone and my finger, to sort of roll off the adhesive. I love how it looks, hope this helps.
I remove mine with my fingers and nails :act064: and there was no sticky residues.. ;act028:
it was really easy since the truck was new. :act024:
I have known of people using dental floss ( not the plastic ) and Goo Gone. Slide the dental floss behind the emblem using Goo Gone to disolve the stickey stuff that holds the emblem on. Then use a sawing motion with the dental floss, adding the Goo Gone periodically to keep the stickey stuff desolving. We removed the emblems from a Honda VTX motorcycle tank this way. Be patient and they will come right off with no damage to the paint.
I used to work in a body shop, in order to remove pin stripes and adhesive, we used a rubber wheel that you can buy from a car paint/supply store. It fits right into a cordless power drill, work super super fast. I could remove pin stripes on both sides of a vehicle in about 4 minutes. Its a lot like an eraser on a pencil. Never had to worry about hurting the paint. I believe the cost for one is between $7 and $12. Good luck, hope this helps.
Goo Gone automotive is a winner in my book. It will take all residues off no problem.
1 - 17 of 17 Posts
