1 - 5 of 5 Posts
Hi,
I have a very small dent in my rear driver door that should just pop out.
Is there any instructions on how to remove the rear inside door panel?
Installing rear sensor came close, I may have to break down and buy the manuals.
thanks.
This will cover it:
Front Door speaker Upgrade How-To (pt 1)
The only difference you'll have for the rear door from the front door directions would be the fact that the "sail panel" will be at the rear of the door.
Good luck with the dent.
Hey ridgeNH, I would be much obliged if you would let me know if when you tear into the door, if there is styrofoam in there like you can see inside the front fender. I have this squeaking sound that comes from my drivers door that is making me crazier that I already am :eek: thanks, sorry to go off topic :eek:
Discussion Starter · #4 ·
Will do,
I have a dent I am going to try and fix. Got to get the camara out and document it.
ernie
1 - 5 of 5 Posts
