Yes, this has been brought up before, a few speculative ideas for repair have been offered, but a specific repair procedure has not elaborated upon.Wasn't there another thread discussing this very thing? If memory serves, those nuts internal to that support are only meant for that plastic and have the weakest of tack welds holding them in place. That's why No-Lo switched to the u-bolt setup for the front skid plate. If you want to repair it, my suggestion would be to use rivet nuts. They're inexpensive and easily found on Amazon.
Ask and you shall receive: How to install rivnuts on the cheapYes, this has been brought up before, a few speculative ideas for repair have been offered, but a specific repair procedure has not elaborated upon.
Thanks,
Bill
I fully understand how RivNuts work, but are they really appropriate for this repair?Ask and you shall receive: How to install rivnuts on the cheap
Stainless steel rivnuts from Amazon: Click me!
I don't see why they wouldn't be. It also depends how far down the rabbit hole you want to go in disassembling your truck. Personally, I'd go the rivnut route and be done with it.I fully understand how RivNuts work, but are they really appropriate for this repair?
Bill
My point exactly where I would like to know what I am getting myself in for before I start disassembling everything!It also depends how far down the rabbit hole you want to go in disassembling your truck.
When you do I would greatly appreciate reading about your experience in doing so!If that other thread I mentioned is any indication, no one has been down this particular rabbit hole. Also why I said I would just do the rivnut fix and be done with it. Hell, I'm considering doing it as a preventive measure so I don't drag my skid plate due to those OEM weak nuts failing.
I'll be waiting until the spring before I tackle this. In my case, I'll be breaking the OEM ones to do the job. Just curious, with yours, are they rattling around or did they find an exit somewhere on the road?When you do I would greatly appreciate reading about your experience in doing so!
Bill
I can get the screws started, but as I try to tighten the screws they will just spin.I'll be waiting until the spring before I tackle this. In my case, I'll be breaking the OEM ones to do the job. Just curious, with yours, are they rattling around or did they find an exit somewhere on the road?
I already feel those poorly secured nuts starting to loosen up and would rather nip it in the bud before it becomes a problem.I can get the screws started, but as I try to tighten the screws they will just spin.
Why will you be breaking screws intentionally?
Bill
I could get two of the screws to tighten up enough so to secure the plastic parts they were designed to hold. Otherwise, we have learned our lessons about trying to take our Ridgeline off road so we'll probably just recycle the skid plate for what we can get out of it.I already feel those poorly secured nuts starting to loosen up and would rather nip it in the bud before it becomes a problem.
