Hey everyone. I'm really flustered and would appreciate any advice. I have a 2006 Ridgeline RTS. I was on a long commute when the dash lights began to fade, speedometer/tachometer dropped to zero, AC cut off, and a few miles later I lost all power and the truck cut off. A jump start would only get me a few miles before it died again so I tested the alternator, which turned out to not be generating power. (I also had the battery tested and it was fine).
I bought and installed a high-output alternator (200 amp vs OEM 130 amp), jump started the truck, and it ran for about 5 minutes before dying again. I jump started it again then disconnected the negative terminal. The engine died instantly. Clearly its drawing power only from the battery until it runs out.
I should note that when I got the new alternator in and put the serpentine belt back in place, the belt was significantly looser than it was before. It seems to still be spinning each component at the same speed it did before, and I don't hear any squeaking or see shaking (Not sure if this has any bearing on the issue or not).
Is it possible the alternator somehow isn't getting the power its generating where it needs to go or could the loose belt be creating the issue?
I only have basic repair knowledge so any input would be greatly appreciated. Thanks!
