This is a must. I don't understand why it wasn't done already. Posts with actual information get buried without subforums
Sent from my Nexus 6P using Tapatalk
It's a great idea and it's day 1 of you making this less than 2 hours ago. You shouldn't be so quick to denounce it or your work on it.Well since there's been ZERO response it must not have been important after all. Just wasted my time once again.
My mistake. I guess that's not what you or others wanted.
I'll just let it go stagnant and be done with it. I have no idea why I keep getting sucked into caring about ROC. Nobody really cares. Certainly not the owners or Honda.
Just wasting my time.
Well there were strong words said and messages sent to me. I personally replied to those that had strong opinions, but not a single reply.It's a great idea and it's day 1 of you making this less than 2 hours ago. You shouldn't be so quick to denounce it or your work on it.
I would also add when I logged in tonight I was caught by surprise by it and didn't understand it until I found this thread.
I can just as easily undo it. It took hours of work and not a single response, thank you, screw you or anything else.
Tell me how you would feel? You can't because you don't know of all the messages requesting and DEMANDING that this was needed to happen. I granted those wishes and quite frankly none bothered to even respond.
I'm very tempted to remove them. I put MY neck on the line for it. If nobody appreciates it I simply wasted my time (I get nothing from this forum in the way of compensation).
It's a no win situation that I won't bother with again. The format is so screwed up that it would take me many more hours, but there have been over 1000 hits since the changes and NOT ONE single response on the subject other than your negative remark.
There's nobody else that gives a damn about ROC. Only me and I did a lot to try and better this community. No wonder Tom left. The soft spot in my heart is hardening fast.
Why bother? All I get are negative responses. I don't have to do a damned thing. Is it too much for any of you to say good things instead of bombarding me with complaints? If so I'll just turn off my PM and email and forget ROC.
Yes, I worked on that for hours. And quite frankly I know exactly how many members have logged on since the changes and yours is the ONLY response.
There are 232 viewing the G2 parent forum RIGHT NOW. Zero response other than I should have waited longer. No thanks. Not worth my time.
-Joe
'Joe I think the big thing is the hard work of moving existing threads to the new sub-forums. New threads will start but until the old ones are sifted thru and moved they will continue as is.
This venue has been sizziling since I joined.Well Joe you did an excellent Job today. Members will thank you for this sub classifications.
I think this G2 RL forum is going to explode as G2 sales start going up. I don't see a match for G2 in the market any time soon.
Same here. Bet a couple of us could get this all cleaned up in a day or 2.Thanks Joe. I'd be happy to sift through all the threads and start moving them but I don't have those privileges.
