1 - 1 of 1 Posts
Vendor
The Honda Ridgeline Rack 3 is a Heavy-Duty rack that simply bolts into the factory bed and provides up to 500 lbs of distributed load capacity. Designed to carry longer loads, the 86” long rack has 3 crossbars and features a spoiler on the font crossbar to reduce wind noise.This rack was specifically designed for the 2006-2014 Honda Ridgeline.
402643
The RidgeLine Rack 3 carries up to 500 lbs. of distributed load.
402644
The Honda RidgeLine Rack 3 is designed to carry longer loads.
402645
The Honda RidgeLine Rack 3 rack complements the design lines of the Ridgeline as it extends over the cab.
402646
The Honda RidgeLine Rack 3 loads up to 500 lbs.
402647
The Honda RidgeLine Rack 3 has three crossbars for full support.
402648
The Honda RidgeLine Rack 3 spoiler greatly reduces the wind noise common to other over-cab racks.
402649
Honda RidgeLine Truck Racks have this unique cleat. It makes tying down cargo with hooks, straps, and rope a cinch!
402650
Main features and benefits of the Honda RidgeLine Rack 3 Truck Rack:
  • Truss design side rails integrate two crossbars over the bed and support the front crossbar over the cab.
  • Design includes diagonal bracing that ties base rail into the truss and follows the natural lines of the vehicle.
  • Carries up to 500 lbs of distributed load.
  • Overall length of rack is about 86”, with the distance between the front and rear crossbars about 79”, allowing the carrying of rigid loads up to 16 feet long*. Width of the rack exceeds 48” so that standard size sheet material such as plywood can be easily carried.
  • Fabricated from black powder coated stainless steel.
  • All threaded parts are stainless steel.
  • FEDEX ground shipping weight is about 96 lbs.
U.S. Rack Product Warranty
U.S. Rack™ products are warranted for a period of one year against all structural defects in materials and workmanship provided that they are assembled, installed, and used in accordance with all manufacturer’s specifications and instructions. See the merchandise return policy.
Reactions: Carsmak
1 - 1 of 1 Posts
