The Honda Ridgeline Rack 4 is a Light-Duty Rack that simply bolts into the factory bed and provides up to 150 lbs of distributed load capacity and must be used with the factory roof rack. This rack was specifically designed for the 2006-2014 Honda Ridgeline.
The RidgeLine Rack 4 carries up to 150 lbs. of distributed load.
The RidgeLine Rack 4 is simple, sturdy, and attractive.
The Honda RidgeLine Rack 4 rear truck rack is used along with the Honda roof rack.
The Honda RidgeLine Rack 4 requires no drilling for installation.
The Honda RidgeLine Rack 4 can carry wide loads.
Honda RidgeLine Truck Racks have this unique cleat. It makes tying down cargo with hooks, straps, and rope a cinch!
Main features and benefits of the Honda RidgeLine Rack 4 Truck Rack:
Solo Rear Crossbar is used in conjunction with the Honda OEM Roof Rack.
Extruded Aluminum crossbar has a flat oval shape for streamline air flow while carrying medium loads.
Carries up to 150 lbs of distributed load on the crossbar (Additional weight can be carried on roof rack).
Crossbar employs unique truss construction and internal ribs and fir spar to stiffens and strengthen the crossbar
Legs are available in zinc-plated, silver powder-coated carbon steel or in stainless steel.
All threaded parts are stainless steel.
FEDEX ground shipping weight is about 27 lbs.
U.S. Rack Product Warranty
U.S. Rack™ products are warranted for a period of one year against all structural defects in materials and workmanship provided that they are assembled, installed, and used in accordance with all manufacturer’s specifications and instructions. See the merchandise return policy.
