Designed specifically for the 2017-2018 Honda Ridgeline and to carrier distributed loads of up to 500 lbs. The Ridge Rack 5 was designed with the factory roof rack in mind. Both the front and rear rack corresponds the factory height of the optional factory roof rack.
The RidgeLine Rack 5 carries up to 500 lbs. of distributed load.
The RidgeLine Rack 5 is designed specifically for the 2017 and 2018 Honda Ridgeline.
The RidgeLine Rack 5 allows full access to, and operation of the trunk.
The Ridgeline Rack 5 crossbars correspond in height to those on the 2017 & 2018 Ridgeline OEM Roof Rack.
OPTION A – All Metallic (Aluminum and Stainless Steel).
OPTION B – Black with Metallic Crossbars (Aluminum and Stainless Steel).
OPTION C – All Black (Aluminum and Zinc Plated Carbon Steel).
Main features and benefits of the Honda RidgeLine Rack 5 Truck Rack:
The clean architecture of this truck bed rack complements the sleek appearance of the new 2017 and 2018 Honda Ridgeline.
The extruded aluminum crossbars and legs, powerful connector hardware, and contoured Base Rails impart a load carrying capacity of up to 500 lbs.
Installs securely WITHOUT DRILLING and can be removed or re-installed in 5 minutes.
Does not interfere with the opening of the Ridgeline bed trunk.
The Crossbars of our 2017 and 2018 Honda Ridgeline Truck Rack are the same convenient height as the crossbars on the Ridgeline OEM Roof Rack.
Eyelets in the Base Rails and Crossbars allow easy anchoring of cargo straps and hooks.
All threaded parts are stainless steel.
This quality product is manufactured in the USA.
U.S. Rack Product Warranty
U.S. Rack™ products are warranted for a period of one year against all structural defects in materials and workmanship provided that they are assembled, installed, and used in accordance with all manufacturer’s specifications and instructions. See the merchandise return policy.
