Designed specifically for the 2017-2018 Honda Ridgeline to carry longer loads and can support distributed loads of up to 500 lbs. The Ridgeline Rack 6 has an overall length of 8-1/2 feet and features our strong oval shaped extruded aluminum rails that incorporate eyelets in the Base Rails and Crossbars for easy anchoring of cargo straps and hooks.
The RidgeLine Rack 6 features an over cab for longer cargo, carries up to 500 lbs. of distributed load.
The RidgeLine Rack 6 is designed specifically for the 2017 and 2018 Honda Ridgeline.
The RidgeLine Rack 6 is designed to carry longer loads such as ladders, canoes, and Kayaks.
The RidgeLine Rack 6 converts the HONDA RIDGELINE into a truly practical work truck as needed.
The RidgeLine Rack 6 looks good on the Honda RIDGELINE during work or play.
REAR VIEW OF RIDGELINE LADDER TRUCK RACK.
VIEW OF AFT PORTION OF LADDER RACK.
VIEW OF FRONT CROSSBAR WITH SPOILER.
Main features and benefits of the Honda RidgeLine Rack 6 Truck Rack:
The clean architecture of this truck bed rack complements the sleek appearance of the new 2017 and 2018 Honda Ridgeline.
The extruded aluminum crossbars and legs, powerful connector hardware, and contoured Base Rails impart a load carrying capacity of up to 500 lbs.
Extends over the cab with an overall length of 8-1/2 feet for carrying long loads.
Installs securely WITHOUT DRILLING and can be removed or re-installed in 10 minutes.
Does not interfere with the opening of the Ridgeline bed trunk.
Not compatible with most tonneau covers.
Eyelets in the Base Rails and Crossbars allow easy anchoring of cargo straps and hooks.
All threaded parts are stainless steel.
This quality product is manufactured in the USA.
U.S. Rack Product Warranty
U.S. Rack™ products are warranted for a period of one year against all structural defects in materials and workmanship provided that they are assembled, installed, and used in accordance with all manufacturer’s specifications and instructions. See the merchandise return policy.
