1101 - 1114 of 1114 Posts
This is the color I am looking at with these rims. Is that Modern Steel? Can you get more pictures?
I just finished a 2-step polish with Sonax Perfect Finish and Menzerna P3800 Finishing Polish. Then I did a ceramic coating.....GTechnic Crystal Serum Light and EXO.
401129
401130
401131
Looks great but I thought you were supposed to apply the ceramic directly to the paint surface and not wax, as it will prevent the ceramic from sticking?
I did not apply wax.....you have to get the paint surface perfectly clean....I did this by chemical decontamination using Gyeon Iron, then I mechanically deco'd using clay. Then I did a 2-step polish to amp up the gloss and remove small scratches and swirls....using Sonax Perfect Finish (its a polish and not a wax), 2nd step was done really to "jewel" the paint....Menzerna P3800 Finishing Polish....then I wiped it down with GTechnic Panel Wipe to remove any polishing oils left on the paint.....then I applied the ceramic coating. Hope this clears up what I did.
Apologies in advance if this has already been done but I haven't found it.
With that said, I thought it might be useful if we had a thread where just pix of the new G2 could be posted. Would be a good way for owners to post pix of their new G2's and to be able to see/compare the various trim levels and colors all in one place.
Soooo.....start posting those pix and list trim level & color !! 😄
(mods: please delete this if such a thread already exists)
How are you liking the CSL \ EXO. I just did my BE last weekend. I did a one step with M205 after a wash and Fall Out. Only 1500 miles on the truck. 1 coat CSL and 2 coats EXO v4. I also did the trim with C4 and the glass in G1. Going to do the wheels in C5.
402099
402100
Looks amazing. Can you translate your language on your products though? I’m not sure what all of that is and would like to look into them.
Qtechniq Products
CSL - Crystal Serum Light is the base ceramic coating
EXO - This is a coating put on top of the ceramic to give it depth and hydrophobic properties
C4 - This is a trim restorer \ protector \ coating
G1 - This is a ceramic coating for glass
C5 - This is a ceramic coating for wheels
W6 - This is a iron remover
PW - This is Panel Wipe, an alcohol based cleaner to take all polish and wax off paint before coating
M205 - This is a Mequiar's product for polishing paint
M105 - This is a Mequiar's compound product for correcting paint
There is more info in the my thread in the cleaning forum - Full Out Gtechniq Coating on Black Edition
