well, i just got my ridgeline and i'm pretty pissed that i can't use my ipod yet. is there any way to rig an auxillary input on my 6 cd changer? (other than doing the stupid radio frequency thingy)
What brand / Model number AUX connector did you use?ridgeln said:I lost count of the number of times I've taken my dash off my Ridge. I bought the adapter for the stock 6CD changer (for my XM - MyFi) and install was super easy (I ended up needing to add in a ground loop isolator, part of why I had it apart a lot). There are a number of plugs that go into the dash, so be patient - some come out easily, others are a little tighter. They all have a release mechanism, so take the time to find it before trying to force anything. The only issue I had was trying to figure out how to move the dash around to remove it - avoiding the gear selector was difficult - make sure you put a soft cloth between it and the plastic of your dash before removing the dash.
There is only one place & way the connector will fit on the back of the head unit.
-ridgeln
