1 - 4 of 4 Posts
Hi!
Iam new here :)
If you but 20" rims on your ridgeline,does that effect your acc and speed very mutch?
Hi!
Iam new here :)
Yes, it reduces your accelleration (both speeding up and slowing down) and your mileage because the 20" rims are heavier, and the mass is concentrated at the perimeter of the wheel.
Flymo
It didn't affect mine because I adjusted my tire... I got 20" Rims but adjusted to slightly lower profile tire.. So there was no difference between the radius of my tire... I also went as wide as I could.
275/45R20 tire
20" x 9" Rims
Check out my photos in my Gallery and you can kind of get an Idea..
I also Attached a PDF that gives you an idea of what size tire and what you have to modify if you went bigger..
Good Luck
Cyrus
1 - 4 of 4 Posts
