1 - 4 of 4 Posts
Hello all, could use some help! If I cant find an answer or possible fix I will take it to local dealer. Hopefully they can diagnose without codes, but at $130 an hour hope its found out quick. I can fix with the help of a mechanic friend. 2006 RTL, 160,000 miles. Started it the other day and had check engine and vtm4 lights came on and idle was chugging. Had codes read, cylinder 1&3 misfire, and multiple misfires. Replaced all 6 coils and plugs. Still had rough idle but no chugging and no codes. I've noticed if I turn ignition to on and wait 5 seconds its starts and idles fine. Help!
2010 RT - Bali Blue
Typically the fuel system in our trucks are very solid and I am yet to hear anyone complain about a faulty fuel pump.
That said, you can check the fuel pump to see if it is pushing enough fuel. Typically the pump primes the system on Ignition 2. I typically wait till the pump stops and then start, typically a 5 second pause (just like you said).
I would say use the 5-sec pause and carry on.
I was going thru you tube videos a couple of days ago and a mechanic in Alaska diagnosed and replaced a fuel pump after going thru the normal causes. He took apart the back seat to get to the pump. Question I have is the filter accessible thru the route to replace the pump?
I wonder if anyone has had a clogged fuel filter and had the filter replaced.
2010 RT - Bali Blue
Unlike the systems of the past, the Ridgeline does not have an inline fuel filter. The fuel filter is on the fuel pump assembly in the tank. I have 240K+ and still on OEM fuel pump and filter with no issues. I reckon the same for about 99.99% here on ROC.
1 - 4 of 4 Posts
