I’m in the process of starting a speaker upgrade on my 2018 Ridgeline RTL-E. I’ve started down the path that @securityguy outlined. This would include the following speakers.
Center: Hertz DCX 87.3
Tweeters: Hertz DT 24.3
Front Doors: Hertz X 165 or Hertz DCX 165.3
I contacted Crutchfield to see what their recommendation would be regarding the Front Door speakers. I was trying to decide between the Hertz X 165 or Hertz DCX 165.3
I was surprised when the Crutchfield Rep was trying to steer me to Hertz DSK 170.3 Component System for the front doors and tweeters. This includes the same tweeters Hertz DT 24.3 and 6 ¾ Woofers. He was concerned that adding coax speakers to the doors, would introduce to much high frequency. I’m not sure if he was aware the Honda has built in crossovers in their amplifiers.
So now to the question for folks with first-hand experience.
Does adding tweeters (coax) speakers in the doors introduce two much high frequency or does the amplifier suppress these?
Is the midrange output improved with coax speakers or would I be better off with the slightly larger woofer 6 ¾ versus 6 ½ coax?
If I do use coax speakers. Any input on the Hertz X 165 vs Hertz DCX 165.3?
Any thoughts on replacing the rear door speakers?
Thanks for your input, I’m just trying to get the best bang for my buck and to only have to do the upgrade once.
