A friend of mine is considering the RTL-T. I own the RTL-E. After living with the "E" for a few months now, there are some relevant comparisons I can make now. Looking for thoughts and opinions on the following when comparing these two trim levels
RTL-T vs RTL-E
- T has no in bed audio. A cool convenience for some but certainly not a must-have for others. A stand-alone blue tooth speaker could remedy this on the T.
- T has no power outlet in the bed. Perhaps more useful than the bed-audio but is it THAT important? Supposedly, you can get a trailer harness adapter that turns the stock harness into a high amp power outlet.
- T has less "tech" than the E. Could be looked at two ways. More tech = cool and safer for some. On the other hand, more tech means more to break or go wrong.
- T uses blind-spot camera in passenger mirror where the E uses sensing on both sides. Preference I assume.
- T does not have interior ambient lighting. A nice feature in the E at night certainly but should this be a significant factor?
- T has 7 speakers @225w where the E has 8 speakers @540w. I've heard both using the same music on the same usb stick and I cannot tell the difference. Both sound great. The extra wattage is supposedly for the in-bed audio in the E.
- T supposedly doesn't have an extra layer of sound insulation in the floor as the E does. This supposedly translates into better audio and reduced road noise. As stated, I could not tell the difference in terms of audio but a road noise comparison would be helpful.
- T does NOT have the sunroof as the E does. Sunroof is nice for the rare occasions most seem to use it. In terms of structural strength, prevailing logic seems to dictate that the Ts non-sunroof is stronger. Also, less mechanical means less to break down the line.
- T does NOT have a sliding rear window like the E does. The Es rear window indeed has the sliding glass. However, to accommodate this configuration, Honda uses two plastic trim pieces above and below the slider which to me seems MUCH less durable and resistant to scratches than the one piece glass unit used on the T. On the other hand, for long items that wouldn't otherwise fit in the bed like boards etc, the sliding rear window could come in handy. Also, again, less mechanicals = less potential for breakdown later.
- The T uses more of a matte finish on some commonly touched plastics for both interior and exterior surfaces. The E is more glossy and polished in these locations (exterior door pillars and gear shift surround etc). IMO, anything glossy looks good initially but over time, can look very bad with scratches and prints. Matte finishes don't show these nearly as much if at all.
I'm sure there might be other differences but assuming we're talking about the same AWD systems, what are your thoughts and opinions on the above SEPAREATE from budget?
RTL-T vs RTL-E
