Removal of the OEM j-pipe;
First soak all the nuts and bolts on the oem pipe and cat back flanges with PB blaster. (I have an 06 so there was enough rust to justify a good soaking)
Remove the 3 nuts and bolts on the cat back flange, on the rear side of the mid cat. I believe these were 14mm.
Remove the 3 nuts on the front and 3 nuts on the rear j-pipe flanges attached to the precats. (this may remove the studs from the cats, but not to worry they go back in just fine) I believe these were 14mm.
Remove the cross member (4 bolts)
Remove the exhaust hanger bracket while still attached to the j-pipe. I believe these were 14mm. *Support the j-pipe with jack stands or have a buddy hold it to ensure you do not drop the j-pipe on your head, foot or anything else.
Gently massage the oem j-pipe off with a little wiggling and pulling.
Total removal time took about 10 mins.
