Here is a tutorial for installation of these awesome things called shadow lights! I was not planning on posting this so I don’t have ALL of the pictures but I will try to explain the best I can using words.
I had some wiring problems so it took a little longer than I anticipated but without that you’re looking at about an hour of your time.
Here is a link to the product I bought.
Step 1.) Door Panel Removal
This was the hardest part of the installation in my opinion. I do not have pictures but I strongly recommend doing some research on how to actually take this off. The plastic pieces that hold the grommets break very easily!
The driver door has electrical connectors to take off and the passenger door has 2.
Step 2.) Drill the hole
The kit comes with a hole saw and a very good one at that!
Find a spot on the bottom side of the door and drill the hole
Then run the wire through the hole and attach the locking ring that secures the light.
