21 - 33 of 33 Posts
· Premium Member
I had 2 wires backwards on sub box, also my box don't have proper internal volume. The magnet almost touches box, I bought this box 2 years ago off eBay when I 1st got truck, its a down fire box, has 2 inch risers on each end box, I was thinking if I was going to trim the risers off and upfire box, I also have 10" sub spacers I purchased awhile back I could install onto box...
Last couple comments on this:
You found one sub was out of phase of with the other but didn't mention if you heard an improvement after correcting. Did you notice a change for the better when you swapped + & - on one sub?
All by itself, the "issue" of the magnets almost touching the box isn't bad. It's seriously doubtful that is the root of your dissatisfaction, it's equally doubtful extension rings will do much except cause other issues.
There is a significant difference between engineered enclosures with carefully selected sub drivers and off-the-shelf boxes that happen to fit in the space available. Having said that, based on your expectations I'm guessing there won't be a viable turn key solution to ring your bell.
You *could* find a box with a little bit more internal volume but the teeny improvement that might make isn't gonna do what you want.
You mentioned perhaps moving to a single driver enclosure, so for what it's worth, MTX offers a very nice design. You may get lucky and find someone close by with one of these so that you can hear it installed. This is the only solution I'm aware of for the RL with design engineering behind it, everything else is made under the criteria of making something that fits space available. Is this for you? I kinda doubt it. Check it out here
As a final suggestion, its very important to have confidence the polarity of connections between the head unit and LOC are correct. The reason is based in the OEM head using "floating grounds" on the - outputs. Aside from audible issues, if R & L side + & - are not correct, crossed connections can "blow" the internal amp - which may not happen immediately. An easy way to determine if these connections are correct is to check that when balancing full L to full R actually results in sound coming ONLY from the L or R sides. Do that as a final check. IF, when balancing all the way L you still hear sound from the R side, its a safe bet there is a problem between head spk outputs and the LOC.
In short, if everything in your current system is correctly connected, and you need more boom than you are currently getting from the box under the back seat, it may be time to consider removing the back seat altogether. Then you'll have room for a bunch of 15's.
· Premium Member
Discussion Starter · #22 ·
Found a ported/vented box @ fox acoustics.. It holds 2 8" sub's which face the back passenger and drivers side door..its .80 cubic volume.. The box he recommend a jl8w sub's..believe its tuned at either 34-46 hz range..
· Premium Member
Discussion Starter · #23 ·
Is there anyone that has heard of fox acoustic boxes..Seems like a nice deal.. Any input on that box..
· Premium Member
OK, this really IS the last thought on this: If you spend your dollars on an aftermarket head unit - and choose the right one - you could benefit from a graphic equalizer that would absolutely assist in adjusting the audio quality of your existing sub. The purpose of an equalizer is to compensate for speaker and environmental influences, right now you have only what the OEM head gives you, which generally speaking SUCKS. And, with a new head you could eliminate the LOC (which is certainly limiting audio quality in your system), gain an electronic crossover (giving you even MORE adjustment options) AND have better overall sound than what the OEM head gives you - PLUS all kinds of new ways to connect things like iPods, ETC and maybe even gain handsfree for your cell phone.
I think you are chasing the dragon here. IMO you'd be MUCH better off spending a few hundred bucks on a new head than the same $ on a box and subs. WAY WAY WAY better off all around.
· Premium Member
Discussion Starter · #25 ·
Maybe I will consider that.. I've heard good things about pioneer, JVC double din..I just really need camera input, subvolume control, iPod hook up, maybe around $350-$400 range
· Premium Member
You don't need to spend $400 to get everything you need. The "AVH" line of Pioneer heads include powerful software and connection options in the under $300 range. For that price you can have:
Adjustable electronic sub crossover control
Individual speaker level control
iPod input and user interface control
Bluetooth phone connectivity
Front and rear camera inputs.
2V pre-amp out to drive the hell out of any amp.
Ample built in power to drive front and/or rear speakers.
A wide range of display options including customization home screen images and backlight color. Might sound silly but thats a pretty cool feature when you play around with it.
Choosing this kind of option would beat the living snot out of a new sub box in your existing system. Depending on where you purchase, an install and wiring kit can be had for free, making it an even greater value.
Personally, I have the AVH-3700 and even though I have nit-picks, I'm pleased with the sonic quality and software control.
http://www.sonicelectronix.com/item_91063_Pioneer-AVH-X3700BHS.html
2007 Nimbus Grey Metallic RTL
Completely and totally agree. I spent a shade under $400 on my Pioneer AVH-P4400BH about four years ago from Amazon. It's performed flawlessly for me and has every connectivity or tuning feature I could possibly need. The 2700 and 3700 models are simply a progression of the technology and are incredibly affordable. Just to prove a point, my component set up front, sub amp, 10' sub and enclosure cost me a TOTAL of about $170. $50 for the components, $45 for the amp, $45 for the sub and about $30 in materials to build the enclosure. It may be inexpensive equipment, but they're of a pretty good build quality with solid performance specs. My audio system is way more than adequate for my tastes even with that cheap equipment simply due to the fact that I have a quality, powerful head unit. Food for thought...
2.5 year old thread revival? Sort of?
I did the stealth box 13 enclosed spoundstream for like $300-350 with amp and wire...self installed. It's behind the seat so there's no lost storage or exposed equipment to allure theft. I get enough sound from it to enjoy full range of music , especially being a 13" driver it hits some lows.
Hey so you fit a 13 behind the seats? Can you please hit me up with some more details? Do you have any pictures? I can't see how it's possible, but i'd like to do that. Thank you!
Welcome to the forum. Being that this thread is quite old and lovestheh2o has not been active here since 2017, I very highly doubt you'll be receiving an answer. The Soundstream enclosure he was talking about is here: https://www.sonicelectronix.com/ite...QP8zs924QqEmCf3RKJbacoCkaaVhK-TX8Zvl5--h5aZoA
However, it's been discontinued for several years now. I, too, have no idea how this thing was made to fit, but I'm sure it's possible. I built my own enclosure for a shallow 10" sub over a decade ago now and it's still going.
3/4" MDF. Sealed the joints and stuffed the box with Polyfil. Easy build. It's a little fiddly getting the box in place in the stock location, but worth it in the long run. Some have powered their stock sub with a small amplifier and have noted much improved output over the stock setup. The stock sub is powered by a 5th channel in the factory head unit. It has been said it only proves around 15-20 watts RMS to the sub. If you put a reasonable amount of power to the factory sub, it will yield better results. It does have its limitations, though.
Reactions: DKavanagh
21 - 33 of 33 Posts
