1 - 8 of 8 Posts
Temps in single digits today. Used the 2017 RL too run across town. I did remote start it and warned it up for about 5 min. Well, while driving it consistently would noticeably shift with a significant "clunk" from 2nd to 3rd when pulling away from a stop.
After getting to our location the RL essay for about an hour. When we left, it shifted smoothly on the way home. No clunk at all.
No innovator lights on the dash. Anyone ever experience this?
I am 27 months and 34.8K miles into ownership. I hesitate to take it to the dealer since it doesn't have any malfunction indicator lights active and the problem is gone.
Yes, it was could out but I've driven it multiple times in cold or colder weather. So, I'm not convinced it was due to the transmission being cold.
Any thoughts/ideas would be appreciated.
Paul
Sent from my SM-N950U using Tapatalk
Well, a few days later and this was a one time issue. It seems that an ignitions off-on cycle fixed something. It has shifted smoothly since this incident. The RL had sat for many days in cold weather so I am wondering if a transmission solenoid/valve was not working. Once it was warmed up it self corrected perhaps???
Paul.
I left for work the other day after my truck was in the garage all night. Immediately after driving down my level road, 1 to 2nd gear it had a hard time shifting and then a bang/clunk when finally shifted. Then again after it shifted from 2nd to 3rd. This bang/clunk is felt throughout the entire truck and is definitely not good for the drivetrain or hydraulic motor mounts. This is the second time this has happened so I immediately pulled over safely and shut off the engine. After restarting and driving again the issue was gone. So either a computer software issue or some kind of temp sensor or pressure switch as mentioned by zroger73.
I have had this issue come up a few times. Definitely gets cleared by turning off the engine and restarting. One more thin to add though, pedal response is very poor during this time, almost like the cylinder cutoff is activated.
Paul
After start up if it clunks just one time at six or nine miles per hour (don't remember which) it's not a problem. It's the ABS module function test clunk when the solenoids activate. Your owners manual will state that as normal.
This is nothing to do with self testing as the problem remains until the it is shut down and restarted. Sound more like a computer glitch that throws it in to limp mode which is corrected by shutting her down and restating. has happened to me probably a dozen times, only in below freezing temperatures. Not exactly thrilled with the "Honda" experience since I just had all the injectors replaced albeit under warranty. My wife's Fiat 500L which is rated the worst car ever has had no issues whatsoever in 120,000 km.
1 - 8 of 8 Posts
