21 - 25 of 25 Posts
I also added a valve stem cap that indicates if the correct pressure is still holding. Easy quick glance for green indicator for ok, if cap is red time to add air.
You need to order the '4.2 BAR' version for 60 psi.
Reactions: cmat1977
2020 RTL-E
I use the Wheelmaster version of this. I have used it before on a prior Tacoma I owned and it worked perfectly, no leaks at the fittings. So I bought another one to use with my 2018 Ridgeline. So far, it is holding air tight, no leaks. I inflate to 65 lbs to allow for some lost air when removing the extension.
Which Wheelmaster one did you use?
Discussion Starter #25
21 - 25 of 25 Posts
