1 - 11 of 11 Posts
Does the Ridgeline have and upper and lower oil well seal for a total of six for each head?
If oil is coated on the coil pack is it likely the upper one that is leaking?
Looking at the parts diagram, the tube is part of the head assembly (likely press-fit at the factory) so there's only the one seal on the head cover.
Chip H.
Yes, #9 in that parts diagram is the spark plug seal in the cylinder head cover. There will be three total for each cylinder head cover, one per spark plug tube.
I don't recall if there's any glue holding it in, or if it's a friction-fit.
Chip H.
I'm 99% sure the tubes are press-fitted into the cylinder head. In other words, they're permanently installed and sealed, and it'd take a lot of effort and cussing to get one out if you had to for some reason.
Discussion Starter #9
You are referring to the tube and not the seal, correct? The seal on the valve cover should be easy, right?
"Should" .. yes. Like I said, I don't recall if there's adhesive on them.
Chip H.
Yes. The tubes are pressed into the cylinder head at the bottom, and sealed to the valve cover at the top with the small round seals. Those seals are not glued in any way to the valve cover -- they fit into a "lip" in the valve cover and you can pretty easily remove them and install new ones if needed.
1 - 11 of 11 Posts
