I'm just about to instal my new JBL component speakers (GTO 608C) in the front doors and wondered if I should use the Scosche SAHR6 Speaker Mounting Brackets or a spacer ring like Heli did in this thread
http://www.ridgelineownersclub.com/...ics/43960-jbl-gt6-6-6-3-4-2-way-speakers.html
Also, what is the deal with the F.A.S.T. system?
Aside from being a spacer to align the face of the speaker with the opening in the door panel, the function of an adapter is providing a mechanical coupling between the speaker and inner door sheet metal, improving the interface of two baffles the speaker will vibrate. In that regard, MDF is more "robust" than molded ABS. The degree to which acoustics benefit from one or the other material is not only subjective, but dependent on other factors such as power fed to the speaker. In a high power system, the more attention paid to coupling the speaker to the inner sheet metal, the better. IMO: the "improvement" offered by the increased density of MDF over ABS is incremental in most applications but is never wasted effort.
Be aware: since the door is somewhat "leaky" (environmentally speaking) anything inside the door will be exposed to more moisture than it would if it were used inside the cabin - sometimes coming into direct contact with water. Since MDF is glue and saw dust, it does not handle moisture well and will decompose overtime.
If you purchase or cut your own MDF plates, its a good idea to spend a little time coating them with spray rubber or moisture resistant primer/paint like Krylon.
Currently, I'm using a combo of 1/2" MDF coated with Eastwood spray rubber. The plates are laminated to 1/4" ABS. The stack up turned out to be perfect, with the door port meeting speaker face perfectly.
A few images for your review:
