1 - 17 of 17 Posts
I basically followed Jasons how to here.
I used this bar from Amazon. however i found that i didnt need to trim back much of the black plastic in the opening. just right on the very ends where is a bit deeper. i mounted the bar as far back as it would go. its resting on the metal bumper and secured via some thick metal brackets that i fabed up and mounted to some factory holes with factory 10MM bolts.
i also used a 30A relay and wired it into my high beam lights. +12 from the under hood fuse block and input for the relay from at the pass side headlight harness.
wow its stupid bright! pulling in our driveway. mind you with live in the country so its pitch black
Would be interesting to see how much light the led bar by itself puts out in that country road setting
i have a 2014 RTL and have installed a 30''x1'' single light led bar and it is super bright,since i installed it i only use the parking lights and the bar.
Discussion Starter #12
Wow. That's pretty bright. Can you post some pics of the mount/bracket?
didnt take pix. its just some L shaped brackets that i bent to fit into the factory holes. installs are going to be different so its not a standard bracket.
Evnash, did you have any problems with the light bar turning off when you turn your hi beams off? I have a similar install but there is enough voltage (about 2.5v with the engine running) to keep my relay from switching off when I turn the highs off. The only reference I can find to this is below but I have tried his solution but no change and because it is archived I don't know what year RL he had. Thanks for any information you have.
http://www.ridgelineownersclub.com/forums/archive/index.php/t-103458.html
Discussion Starter #14
My RTL has dedicated DLRs that are separate from the headlights. so when my high beams are on i get a constant 12v to turn the relay on. i suspect your DLR are integrated into your headlight and they work with lower voltage.
Sorry to revive an old thread. I can't see the pictures on this. Could you repost for posterity? Any issues with overheating?
Thanks!
Discussion Starter #17
Thanks!
reposted old pix of exterior. no issues with overheating at all.
1 - 17 of 17 Posts
