PS fluid is pretty thin stuff. When it mists into the air or runs down a surface from a leak spot, it makes a mess in a hurry. You should be able to ID if it exists, and trace to origins with your eye balls.
Slide under there and get a look. IIRC the rack is roughly located bottom of fire wall, behind the tranny. But I could be misremembering cuz thats where it is on Accords. Follow the steering column output shaft, you'll find it right quick. It's a simple assembly, but a b!tch to get too.
