1 - 5 of 5 Posts
I am replacing my steering wheel. When I removed it the electrical ribbons came out and are now a tangled mess. How do I fix this?
I am not sure but it sounds like you are talking about the clock spring which you should not of had to remove for a steering wheel swap.
If it is the clock spring, there is no fixing it. It needs to be replaced.
OK I got the spring/eletrical connection for the SRS re-coiled but now the VSA and triangle with the exclamation point light is on. Any ideas why this is happening?
You've most likely done something in your original work or repair that has affected one or more sensors. I'd guess the steering angle sensor.
You may be at a point where you need to have Honda hook it up to the HDS and see what's being reported.
1 - 5 of 5 Posts
