1 - 16 of 16 Posts
Hi was wondering if anyone can suggest a good link or video with sub/amp install specified to our Ridgelines for hiding cables etc.
I want to try and save some $ and do it my self.
Thanks !
I did mine myself. And to be honest it wasnt hard to hide them at all. Just patience. I hide everything under the dash then down through the side took the plastic step thingy and found wire harnesses so I pretty much just ran the wires with it since there is a plastic box holding them all in. I wish I had taped all the sub and amp wire in one would have save me the time snaking them one by one.
Re: Will this Amp/Sub Combo fit?
So ive been searching up on a good location to mount a sub woofer on the ridge and wanted to leave space under rear seats for storage.
So after searching up how to remove back seats to remove back stock sub, would i have enough room and how would i go about mounting this type of unit?
I want to make sure before going ahead and ripping off the seats to find out if there no room or a good spot to mount it.?
here are the dimensions
Dimensions: 13.6 x 9.9 x 2.9 (L x W X H) Inches
any help would be appreciated
https://www.ebay.com/itm/Rockville-USS8-8-600w-Slim-Under-Seat-Powered-Car-Truck-Subwoofer-Sub-Amp-Kit/302267122985
Sorry, just realized you posted this in the G1 section....DOH!!
2010 RT - Bali Blue
@Jorge_Ridgeline; I recommend using the space behind the rear seat's back rest. I have two of my amps (main speakers and sub) just as @Captive8 showed. My wires run along the driver side and passenger side door trims. Oh yeah, I have sub back there too. You cant see anything when I open the doors and I can still use the interior space as designed.
The only thing that is under my seat (passenger front) is the fused power distribution block. Make sure that the lead to this distribution block has an inline fuse.
That’s what I figured also , but this doesn’t help me with knowing where to run the battery wire and head unit wires to the back of the vehicle ?
By just guessing do the front/ back door trims just pop off so I can run the wire under there?
2010 RT - Bali Blue
As far as the battery lead wire, it came from the battery, through the firewall (via an existing grommet) down the bottom of the center console, crossed over and then towards the passenger front seat to the power distribution block. This distribution block powered the amps, my 400W inverter, and my carpc.
All my audio cables ran along the driver side door-sill. The power and remote turn on ran along the passenger side door-sill. The plastic panels on the door-sill just pop off. The only one that needs a tool is the plastic trim that the seat belt anchors through.
Thanks !
Hey Jorge_Ridgeline, I saw your post and wanted to share what I did with mine. It may help you if you haven’t already finished your project. Good luck!
https://www.ridgelineownersclub.com/forums/9-1g-mobile-electronics/200346-2008-audio-upgrade.html
2104 Honda Ridgeline SE
I have an '09 RT. Will the OEM sub woofer box fit? or is there something about the RT that it won't? With that said, would I assume that the stock box isn't soo bad? I've seen a vid with a woofer upgrade along with an amp.
It is all about your goals and what you compare it to. I'm slowly getting there and my plan for bass is removable subs. If I need to carry a lot of stuff with the seats up, I will remove all subs. Seats down with 3 people, a 10" sealed under the seat. Seats down with 2 people, a 12" behind the console. Small seat up, a 15" sub sitting there. Big seat up, an 18" sub sitting there. Both seats up, dual 15's.
All of this will be accomplished with a single amp and Speak-On quick connect speaker terminals on the boxes. The amp I have has about 2,000w on tap but I can vary the wattage output using drivers of different impedances.
JL Audio makes a custom sub/enclosure for the 1st gen RL. It fits under the right (smaller) rear seat. You will need an external amp to power it. I snagged one on CL at a good price.
im running 2 15" DC Audio Level 4s with about 3200 watts to just the subs. i have them in a 6.5 cube box behind the drivers seat, and i still have ample space to fit an adult in the passenger single seat. im looking at making a 4th order wall behind the driver which would still net me that extra 3rd person seat. The ridgeline has a lot of space. I also have a battery back there, and will be installing 2 more batteries to support the system at full tilt (5000 watts). The space under the passenger seat i have my tow straps, and some grocery bags, an umbrella, small tool kit, and a pair of slippers.
Discussion Starter #14 (Edited)
Thanks for the suggestion Heli.
Is this the Same unit ? Because I clicked on your.link and said those boss amplifiers were discontinued..
I currently have a 2010 with a pioneer double din and looking to replace stock tweeters ..
BOSS Audio CE200M Chaos Epic 200-Watt Monoblock, Class A/B 2-8 Ohm Stable Monoblock Amplifier https://www.amazon.ca/dp/B0077IA7FG/ref=cm_sw_r_cp_apa_i_zuIuDbGA3Z5CZ
Sent from my SM-G960W using Tapatalk
Well...we are about to find out.
I just bought some replacement door speakers for my 06 RT and while I was at it, I picked up one of the Rockville 10 inch 800 watt (200 rms) subs. I figure if it doesn’t fit, I can return it for a refund. I will post my install next week after I do it and link it here assuming all goes well.
395689
1 - 16 of 16 Posts
