1 - 11 of 11 Posts
Hello fellow owners
I installed OEM tailgate lock about an year ago and about 6 months I started having issues opening the tailgate using the centre handle. I had to push in the door and then pull the handle simultaneously to open the door and now it completely stopped opening. I removed the panel to inspect the linkages nothing obvious is broken I started bending them to remove play and handle started working but only after kind of resetting a linkage so it works fine until I open it once sideways after that back to the same issue. Anyone had this issue and found a fix please share? It seems quite complex so far. I don't want to go too deep and mess something that still works fine. Out of warranty as the truck was purchased in July 2016. My gut feeling is I pulled on the handle too hard when the tail gate was locked. It is confusing sometimes to tell if it is locked looking at the keyhole.
Hmm, there was no OEM tailgate lock for the 2017 model year, unless the Canadian model was different. Perhaps contact the manufacturer of that lock you installed.
By "add on" do you mean "aftermarket" or "optional equipment"?
They released it as optional equipment and you can buy it and install it your self or pay the stealership to do it. Part number change by color of tail gate so multiple part numbers out there.
That picture shows the yellow tab disconnected. Any chance it came loose?
No I disconnected it for troubleshooting purposes. No tabs are broken. Nothing I found loose so for.
Discussion Starter #8
It is an OEM lock that you can buy from Dealership for like 100 bucks by ur paint code for a color match
404434
404435
I replace the lock and handle with the factory oem painted unit. Work ok in the beginning no problem. Later on had a hard time opening the tailgate down. Lubed the Outside lock on the Tailgate door . Which helped . The real problem was the latch and striker on the right side needed to be adjusted on the tail gate door. I lowered it down slightly. The brass looking striker right side of the tailgate Car body 2 screws .
Discussion Starter #10
Finally thanks buddy. Can you post a picture of which one u are talking about plz.
404436
1 - 11 of 11 Posts
