The tailgate does not have a lock. The trunk under the bed locks with the doors.
You can add an aftermarket lock like pop&lock and I believe its dynolockHow can you lock the tailgate on 17 ridgeline?
Both good ideas and another member installed a sliding lock barrel bolt on his tailgate. The sliding bolt lock is low tech but effective & cheap.You can add an aftermarket lock like pop&lock and I believe its dynolock
Its a pretty easy process
are you kidding? :surprise:... and another member installed a sliding lock barrel bolt on his tailgate. ...
