1 - 8 of 8 Posts
Bug and tar remover?
Yep I used it the other day. It worked very well.
L
Guest
Go to a roofing supply store and get the pink ( or use to be ) wipes they use for cleaning tar. They kind of look like handi-wipes. They work like magic!! :D
Goof-Off also works very well; however ALWAYS test it on an inconspicuous area as it can remove some paints, and melts alot of plastics.
Citrus based solvents are specifically designed to remove tar and petroleum type products add water to reduce strength and wash with any detergent after you finish to remove the product from the area you used it on.
Good luck
1 - 8 of 8 Posts
