Several people including myself have described a mystery sound my truck makes when going down a bumpy road. The sound has been accurately described to be like a tennis ball in a cardboard box being shaken. It seemed tied to wheel movement up and down - not to the body of the truck itself.
I looked extensively for it with the truck fully assembled and found nothing....I'm in the middle of putting new struts on the truck among other things and found the source of the sound. Not only that, I think I figured out why it doesn't make the sound when new and even later it only makes the sound on some of the trucks.
Here is the culprit:
51722-SJC-A02 RUBBER, FR. BUMP STOP
It's number 12 on this diagram.
It's basically a cylinder of rubber that slides on the strut shaft to make a soft landing when the suspension bottoms out. I believe it's either glued or press fit into the "Bump stop sleeve"(Number 10 in the diagram) which is held at the top of the strut assembly normally. On trucks that make the sound, it comes loose and basically bounces up and down riding on the strut shaft making the mystery sound. Thats the theory anyway...Nothing else could make the noise I've been hearing. I don't think there are any negative effects beyond the sound itself, but I'm considering ways to eliminate the noise anyway...it doesn't sound good...I may end up gluing it back onto the sleeve.
Also, I've heard this noise on other vehicles with struts and am pretty sure it would explain the noise there too.
