The Ridgeline "285" Tire Club
15349 Views 34 Replies 17 Participants Last post by  radz182
Just did a lengthy write up, only to have the web cut out and lose it all.
Details:
-The primary goal of the kit is for beach sand clearance and floatation here on the ocean.
-I wanted the widest squarest tire I could find, that was 2 inches bigger in diameter. This gives me 1" of lift on tire alone. This 285 Nitto Terra grappler was the only tire that fit all my criteria, at 31.47" tall. They are beautifully made, and very precise. They ride awesome at 65mph, and I didn't even balance them as they are for temporary beach use on the weekends.
-the lift kit is a front 2.0 Kwik-Change, which has the ability to return the truck to stock height and alignment in 3 minutes flat. Then the oem wheels go on for the week.
Overall lift is 1" (tire) in the rear, and 3" (2+1) in front.
-will add details here as time goes on
Short version, new beach setup, this truck is literally unstoppable, no matter how deep the sand gets. The SH-AWD system in SAND-mode quickly propelles the truck forward like it's on pavement with 0 wheelspin. With the wide Nittos, it leaves a very shallow eco-friendly footprint that pleases the oceanfront homeowners, beachgoes, and piping plovers
anyway, here's a pic, will follow up when the web is stable.
Reactions: 5
1 - 20 of 35 Posts
Where did you go out on a beach? I'm looking for a quick off road fix!
Right on the ocean. Hampton Bays, Quogue, Westhampton. There are 8 4x4 launch ramps down the coast in the town of Southampton.
Too bad about losing the writeup. I'd like to learn more about what you've got going on there. Or at least maybe I'd like to see some more pictures!
Added some details, will continue to add to top post.
Reactions: 2
That has to run pretty bad when turning.. as the 265 rubbed.
Looks good though!
Sent from my iPhone using Tapatalk Pro
The lift kit moves caster (not camber). There is no rubbing.
I have never heard of that lift-kit. Do you have a link to information on the product?
Interesting as that's different from the other kits. Not to mention wheel offset is a factor as well.
265's run at full lock, so obviously curious how you got a 285 to fit.
The kit is a one-off Billman Motion kit. It retains stock camber, and is caster adjustable which moves the wheel forward, preventing rubbing. The premise is to retain the stock truck ride and handling, hence the quick change features.
I would eventually like to put the kit into production, but the S2000 business consumes all my time right now.
Reactions: 2
Interesting, that would be a very nice kit.
Your truck looks great OP! Thank you for sharing!
For clarity, the tires are 285/60R-18 Nitto Terra Grappler G2 and the wheels are 18x8 ET+35 Raceline shift. This combination sits ~1-inch further towards the fender when compared to the O.E. wheel and tire set-up. There's also ~1-inch more clearance towards suspension compentests as well.
Thanks man. When I ordered them from you guys, the guy asked "you sure about this?"
Thank you for your business!
This fitment isn't overly aggressive, besides the tire height, so I'm surprised you were asked that. Glad you went for it!
Don't quote me exactly, he did know instantly it was for lifted application. Thanks for help with these!
Reactions: 1
You got it; thank you again for your support!
The kit is a one-off Billman Motion kit. It retains stock camber, and is caster adjustable which moves the wheel forward, preventing rubbing. The premise is to retain the stock truck ride and handling, hence the quick change features. I would eventually like to put the kit into production, but the S2000 business consumes all my time right now.
Total tease, Mr. Bill! :)
I think your kit would be a real winner. Without giving away patentable information, can you tell us if your prototype lift kit would allow variable height adjustment from 0.0 to 2.0" (e.g., 0.5/1.0/1.5")? Also, am I correct in assuming the 3 minute-return-to-stock-configuration would require no removal of wheels and no special tools?
PS: Having you on the ROCF and actively innovating/testing modifications for the G2 RL is awesome!
Reactions: 1
Height is not variable adjustable, but could make the parts any size for any desired lift.
Wheels need to be removed to revert back to stock, takes about 3-4 minutes after the wheels are off. Taking your time, 4 wheels and lift can be done 10-15 min tops.
Reactions: 1
Thanks for the follow-up! I know that in your case, "return-to-stock" requires re-mounting your OEM wheels/tires, but what I was most curious about was if the wheels need to come off in order to access the lift-adjusting hardware. In other words, if you were driving on stock wheels for several hundred miles to an off-road adventure, could you simply raise the truck 2" without removing the front wheels when you got there? You're saying "no", right?
And when you say the parts could be made for any size lift, I'm thinking that you may have solved the dilemma of having to trim the length of the upper strut mounting bolts to accommodate lift spacers thinner than 1.5", correct? I'm asking because all I would want is a 1" front lift for more clearance and a slight bit of rake retention with minimal effect on drivetrain configuration, handling characteristics and fuel efficiency. But as we've seen from Jsport, Truxxx and Traxda, the OEM upper strut mounting bolts need 1.5" of clearance to fit between the lift spacers and the strut mounting surface.
1 - 20 of 35 Posts
