1 - 1 of 1 Posts
I noticed that my RTL has a great control for the cabin temperature. You can set it for very hot or very cold with anything in between. However, it does not display current temperature. Well for the last few days I was on a goose chase looking for a dash mounted thermometer. I check Pep Boys, and various other autoparts stores for something that was dash mounted. I found a few things; inside and outside tempoerature displays complete with all kinds of wires. Radio Shack has a wireless one. Whitney had little. What I was looking for Radio Shack had a few years ago, it was a disk about an inch in diameter with a sticky back. Add a flat battery and peel off backing and stick anywhere. They don't make it any more. I think it was about 12 bucks.
I found something a bit more expensive, tho I would think a bit more acurate. It is an analog device that is liquid filled. usually goes on a motorcycle. Here is the site if anyone is interested; http://www.formotionproducts.com/.
They ain't cheap, but should do the trick. Glows inthe dark too.
1 - 1 of 1 Posts
