641 - 660 of 864 Posts
Not sure if anyone posted this but with the adaptive cruise control, road departure and lane-keeping, the Ridgeline will drive and steer itself softly even though light curves on a freeway. You can feel the steering wheel turn when you enter a corner. When the corner gets sharp enough, you gotta grab the wheel. Not sure if this is a Black Edition feature only (RTL-E?).
Touring does that too. Weird sensation for sure.
2018 Honda Ridgeline RTL-E
Yup, the E does it too. Rather disconcerting actually. The first couple weeks I played around with it, then decided to shut it off. I suspect your correct in assuming it a precursor to self driving trucks.
Lots of my rental vehicles have that feature now. They keep getting closer to the car driving itself. Some manufacturers are closer than others (think Tesla).
Steve
the Honda self driving thing is more like a warning system. It doesn't actually drive your truck, but will try it's best to keep you in your lane.
However, this doesn't work if it can't see your lane (snow, gravel...)
2020 Honda Ridgeline RTL-E
From my understanding it is to aid in reversing. It's tilts down so you can see the rear wheels and anything endangered of getting run over.
It's also quite helpful when backing up with a trailer (at least the trailer for my Waverrunner).
2021 RTL-E, Lunar Silver Metallic
Help me envision this..... what is the advantage to the mirror tilt down?
I find it very useful, especially the passenger side, to see how close I am to the curb. It is useful if the vehicle does not have surround camera's.
Now with 600 miles on our '19. Things I have noticed...
The brake pedal is mushy when trying to stop hard. It does stop, it just has more travel than I've seen in any car.
The transmission is slow to decide what to do when trying to accelerate.
The throttle response is typical "fly by wire. " Poor.
Wife says her feet aren't getting heat like every other car we've had.
Get ready to live with the mushy brakes. My Tacoma was just as bad, if not worse.
2020 RTL-E
On the 2020 with idle stop, once the engine stops you can restart the engine by bumping the steering wheel. Engine restarts and stays running. Restart is fast and silent.
IME, if you slightly oscillate the steering wheel back-and-forth when you're coming to a stop until you are completely stopped, idle stop will not engage. Once you are stopped, give it a sec or two and you can stop shaking the steering wheel. ymmv
Probably already covered but I was streaming music via Bluetooth. I usually use the fast forward and back button under volume to skip tracks.
Well I discovered that the push select button does the same function by rotating it.
