I recently purchased a 2007 Ridgeline. It needed the timing belt changed so we did that. Also changed water pump, tensioner, serpentine belt, spark plugs. No error codes when we first started it back up but about 20 miles later we have multiple error codes.
Codes in order are:
61 - low voltage
52 - anti lock brake pump relay
72 steering angle sensor
PO420 - O2 sensor catalytic converter
Had battery checked at O'Reilly's. Said battery, alternator, and starter all showed fine. Of course I've had them say a battery was good when it wasn't. No clue how old this battery is as I bought the truck used.
Cleared codes and within 20 miles all were back again.
Thoughts? Fuse relay?
TIA for your help. We had great help here for changing the timing belt.
Codes in order are:
61 - low voltage
