There are pros/cons to timing belts vs chains.
Timing belts are generally quieter. Timing chains stretch over time and the engine loses performance.
So, if your engine has a belt, it should still run like new, power-wise, when it has 150k miles on it (assuming you changed the belt!). The engine with the chain could likely be feeling tired at that point.
Yes, the expense is a PITA. Prices range from under $700 to close to $1k, depending on which dealer you take it to. Independent repair shops typically charge around $500-$600. I had my Accord four-cylinder done a few years ago for $400 by a small-town independent shop. You can also do it yourself if you are mechanically-inclined. My time is valuable to my family, so I let the independent repair shop make a buck off of it to help support his family.
Best thing to do is budget ahead of time so that it isn't a hit to the wallet. There is probably 20k mile (or more) leeway in the repair timeframe, depending on the environment your vehicle is operated in.
Joe indicated that the trans coolant line issue had been addressed on the G2.
