1 - 3 of 3 Posts
Planning on grabbing a set of 20 x 9.5 with 38mm offset, and I'm stuck on what size tire to grab. The two I'm debating between are:
275/45/20 OR 265/50/20
I'm wondering if I should get the 275/45 since it's a slightly wider tire which I would need for a 9.5" rim, or if it's better to get the 265/50 for the higher profile and larger sidewall, but may have a slight stretch.
Any thoughts/feedback would be great.
Thanks!
Thanks!
If there's no rubbing issues my choice would be the 275 tire, plus you'll have some protection added to the wheel.
I had a set of Scorpion Zeros available for $300 so I grabbed them. They are 255/50/20s with only 1k on the tires so they are basically new. All of the wheels I was looking at were 9s......which would have fit great....the wheel I ended up choosing is a 9.5. Every tire is different in terms of actual coverage. Another brand with the exact same size might fit different. We will see how it goes. If the fit isnt right I will switch to a 265 down the road. I believe they might rub based on the lowering.
1 - 3 of 3 Posts
