Or "cocking" the tire on the hub and tightening it up harder to make up for it.
That was a great ride home.
Never again.
Or "cocking" the tire on the hub and tightening it up harder to make up for it."" How can you mess up rotating tires ""
Answer: Cross threaded bolts
Breaking off wheel studs, scratching wheels, misplacing valve caps, etc.How can you mess up rotating tires, with the possible exception of not getting the lug nuts torqued properly? But even that is easy enough to confirm after the heavy stuff has been done?
Bill
Good for you - doing your own wrenching. I'm rapidly approaching my next milestone, 80, and I still do the majority of wrenching on our 3 vehicles. Even so, tire rotation is one task that I let the tire shop do. The key is finding the right shop and getting to know the key personnel who will do everything to your satisfaction. I always appeal to their "expertise" while letting them know, in a non-confrontational manner, that I know how it's supposed to be done. I provide them with a printed sheet showing the rotation map, torque specs, and air pressure. I also request no air guns and the proper use of a "real" torque wrench, not the torque sticks that so many misuse. This continues to work quite well for me and I'm usually invited to watch the process. Just some thoughts should you decide to turn this maintenance task over to someone else - it's possible, with some coaxing on your part, to get exactly what you need - and it will be a free service. Good luck.Looking for a device that can help lift my mounted tires when rotating for easy remount.
I just did my first tire rotation and determined by the time I got to the 4th tire - I was struggling. At 68 I’m guessing this is only going to become more of a challenge. I love doing my own maintenance as much as possible and plan to join the 265 tire club as soon as these Firestones wear out.
That said - I’m wondering if anyone can recommend a tire/wheel lift that helps position the mounted tire correctly to easily remount. I’ve seen a few on Amazon, but they range from $125 - $500. Is anyone using a tire lift that you’d recommend? I know I can always go to Discount tire - and that is likely where I’ll buy my 265s when the time comes - but it’s still fun to do some of my own work. I torque just right and don’t over tighten. Besides - I just bought a Dewalt battery powered impact wrench. Gotta justify that purchase! Thanks for any advice or recommendations.
I just left Discount Tire after getting our tires rotated and I will apologize ahead of time where they provided the usual exemplary service where I have absolutely no complaints, only compliments!We have used DT multiple times, but they have messed up a couple of times.
My dirty look face was a joke. Hopefully, none of your tires will fall off due to loose lug nuts (just kidding). However, I actually was on corner 1 of an autocross where a tire company put on the wrong lug nuts for some new wheels this guy had bought for his car and as he turned in my direction with another corner worker next to me, all four wheels came off simultaneously and he was headed for use griding on the rotors on the ground. I grabbed the woman corner worker and we got out of the way because it looked like the car might not stop in time for us to be safe. This happened about 6 years ago at South Georgia Motorsports Park parking lot and was captured on video I believe.I just left Discount Tire after getting our tires rotated and I will apologize ahead of time where they provided the usual exemplary service where I have absolutely no complaints, only compliments!
Again, I am sorry! 😈
Bill
But how do you know they provided "exemplary service"?I just left Discount Tire after getting our tires rotated and I will apologize ahead of time where they provided the usual exemplary service where I have absolutely no complaints, only compliments!
I just did that this morningThere is a oh so much simpler way, just take your Ridgeline to your local Discount Tire store and they will rotate those tires for free.
Bill
I think Discount Tire is better than most tire shops, maybe even the best, but that is a low bar.Discount Tire is awesome IMO...Its a great customer geared model that does not chrage you for rotations even if you have never used them before.
I do apologize for the issue with your wheels being scratched during service. I would like to know more about this if possible, and see what I can do to assist with this issue. DM headed your way.I think Discount Tire is better than most tire shops, maybe even the best, but that is a low bar.
They scratched the hell out the barrel of my wheels when taking old wheel weights off.
And you can also use those to break into your vehicle!Just an idea, but I'm thinking two of these might work. I've used them for many other lifting tasks and they work well. I would place them under the tire but a little to the front and back so that as you inflate them (both at the same time or taking turns pumping each a little at a time) the tire gets lifted in between the shims. They'll easily lift the weight and once you raise the tire up the inch or so needed, you might need to adjust a small amount but that shouldn't be too hard to do.
I am the exact same way.Same here, I had to request the proper tire rotation (arrows to the correct location) and usually they didn't mess with tire pressure but last trip they reset my tires down to 35 (warm) so that when cool the pressure was too low. I also re-torque the lug nuts (I have even stopped in the parking lot at the dealership before I left to check the lug nuts and also the oil level). I also mark my oil filter with a sharpie so that I know it was actually changed (since Honda recommends/allows oil filters to be changed every other oil change) and I pay for and WANT the oil filter changed every time I double check it. So far they have changed it each time. Am I a little OCD about maintenance? Perhaps but in my decades of car maintenance I have avoided any maintenance related failures and see no need to change my regimen now.
