21 - 40 of 1004 Posts
SixOpRidge said:
Select your Start button, then "Run..." and type in "mspaint" and click ok. MS Paint should open up if it exists, otherwise, you should receive an error.
-SixOpRidge
Well, I have tried it all. I tried Run, and it said it could not find mspaint, so I guess I do not have that. Nothing seems to be working? Any other suggestions???? :confused:
DWdrums said:
email your pics to me: [email protected] I will do it for you
DWdrums-
Thank you for the offer. I e-mailed them to you just a while ago. Thank you very much, I appreciate it greatly. :)
H20MAN, for future use you can install MS Paint by opening the "Control Panel" in "My Computer" and clicking on 'Add Windows Components' or something similar, depending on what operating system you are using. You will probably need to have your original Windows CD available. Once the utility starts just find the box for MS Paint and check the box. The rest is automated and will complete the install for you.
Discussion Starter #27
**Updated---Please see first thread for new pics***
, see H2Oman's bad ass tires and rims, That's what I'm outting on mine. MAN THAT LOOKS KICK ASS
DWdrums- Thanks again for all the help on the pics and the kudos. I e-mailed you the wheel and tire info.
I know several of us were concerned that putting anything bigger might pose a problem with either the handling and/or safety aspect of our trucks. Does anyone know if this has been confirmed?
Also, I see that several of ya have low-profile tires with your new wheels. Notice any difference, ie bump-steer, increase in tire noise, handling, rougher ride? Great pictures!
Discussion Starter #33
Thanks. Good questions. looking forward to answer
The wheel and tires are within about a half an inch of the factory wheels. I think it handles and drives better, they are a little wider and that will make a difference. I think it just changes the whole dynamic of the vehicle with them on. Not sure what I am going to do when winter comes, I hate the stocks. Might get the chrome stocks off ebay for $500 and send them mine.
EDIT:
Never mind, found the answer.
TSW MONDELLO
20X8.5
35mm offset.
What's the spec on the wheel?
20"X?
Offset?
and most importantly, brand?
thanks!
I think it's reasonable to expect a rougher ride on tires that have shorter sidewalls. It's probably going to effect your acceleration and handling since the wheel tire package will be heavier. Road noise will depend mostly on the tire selection.
shingles said:
EDIT:
TSW MONDELLO
20X8.5
35mm offset.
20"X?
Offset?
thanks!
The tires are TOYO, from Les Schwab. They are 255-45-20. These seem to really good for road noise, my wife had them on her first Pilot which had 18's on it.
Here are mine! Alsalsa63
